Engell
Greatings from Denmark
Hi fellow Alfa enthusiast...  :hello:
Actually I don't have an Alfa yet, but I'm planning to get one from Germany in the very near future.
SO do any of you have links or hints to a "quick guide" for what to look for, when buying a 916 3,0 V6?
I've had an Alfetta many years ago, and know how to make a "general inspection" - But was thinking that some of you had some great tips ;)
I'll of course keep you all posted. The one I'm looking at right now is a nicely maintained 2001.
Thanks a lot in advance  :thumbsup:
/Claus
Hi and welcome, some reading in this link maybe helps http://www.squadra916.com/forums/topic/778-alfa-gtv-buyers-guide/ , when you are after a 3.0 24V make sure that timing belt, tensioner, idlers and water pump are changed recently, as it is a costly engine service to do if you are not able to do it yourself or include the cost for timing belt replacement when you negotiate on the price of the car.
med venlig hilsen, GTV-TB
Welcome to the forum and good luck with the purchase!  :thumbsup:
Also check the rear suspension. It's not a very large cost to get the rear rebuilt, but try to avoid. You can get PU bushes like Powerflex or Strongflex if needed.
All belts and the water pump has just been exchanged... new and/or refurbished brakes... all fluids... suspension checked etc.
But the suspension is not that important, because I'll upgrade it anyhow.
Thank you for the link... Will read it from start to end  :thumbsup:
/Claus
Thank you...
Yes, the suspension will be upgraded with PU bushes... and a coilover kit.  :smile25:
  On 2/18/2015 at 08:16, charlee said:
charlee, on 18 Feb 2015 - 09:16, said:
Well, you're all set then :D
+1 :)
